Hey guys I have a few questions for you all. I just recently purchase a new to me 2006 Okanagan 811SL truck camper. Which just happens to be the very first truck camper I've ever owned, so you can say that I'm fairly green with the camper. My question is that when I have the camper in my truck and it's tied down ( I use torklift frame mounted tie downs and their XL spring loaded turnbuckles). The bottom side of the over hang is only about 3/4" from my clearance lights on the roof of my truck. So when I hit a good size bump I've noticed that the overhang will hit the cab lights and make some noise which is a little unsettling. Do you guys have any suggestions as to what's going on?
For some more info my truck is a 2010 F350 super duty 4 door long box diesel. I also forgot to mention that the truck camper already sits on 2 sheets of 3/4" plywood that I've guled and screwed together and notched out so that I can keep my 5th wheel hitch rails installed in the box of the truck. I have a goose neck dump trailer that I tow for business.
So should i increase the height in the bed by adding 2x4 under the plywood? Or am I not tighting down the camper properly? Thanks for any help.
