- Not to hijack the thread but since we have people reading these threads of all experience and education, I just want to add a note about all of these reference wiring tables and standards (NEMA, ABYC, SAE, etc.)....
For each wire size selection, the wire length you should be using for your calculation is for both the POSITIVE and NEGATIVE wire segments ADDED TOGETHER in length. So if your proposed POSITIVE wire run is 6 feet long and your proposed NEGATIVE wire run is 4 feet long (to complete that circuit), it's a total of 10 ft of wire (not 6 ft).
Be sure to use the correct voltage combined with the expected amperage over the total circuit distance to find your wire gauge.
And as very well explained by some of the other writers here, consideration should be made for the temperature in the environment that your wiring is going to live in.
By example...for really cool looking wiring installations (like when I built a custom wood traditional-looking hotrod ski boat with an exposed supercharged 1st Gen Chrysler Hemi, I ran all of the exposed wiring in PVC tubing which gave it a great finished look, but which could trap heat and create a problem (due to lack of ventilation, and the poor thermal conductivity of most Plastics).
So in that case, I made sure my wiring was oversized to keep everything running cool. (And yes, all the wires were tinned, and of commercial marine grade, and terminated with soldered tinned lugs).
BTW, as pointed out indirectly before by someone else, there are pretty dramatic differences between low-cost wiring and the more expensive high performance grades. You will notice that cheap wiring has larger strand diameters with fewer strands. More expensive grades will have smaller strand diameters with substantially more strands.
Both wires will have similar outside insulated diameters, but look dramatically different inside. Also, the more expensive wire will be of higher grade alloy and more resistant to corrosion and fatigue failure. Also, the more expensive wire will use a higher grade of insulator jacket compared to the cheaper grade.
NOTE:
There are several things I can think of that are impacted here.
FIRST: If we accpt that electrical current runs on the surface of wires, then we want a greater surface area to carry our current. The more expensive wire has a greater surface area so carries the current more efficiently.
SECOND: the finer stranding of the more expensive wire makes for much easier positioning and routing of your wire as it lays down nicely and makes turns much easier.
THIRD: The more expensive wire is more tolerant of inadvertent nicking (as someone said "skive marks"), surface damage, and degredation due to corrosion - as there are so many more strands distributing the electrical load.
FOURTH: I don't think anybody's seriously producing low-grade wire with tinned strands and high-quality jacketing. So I think a pretty safe bet is if you go with tinned wire, you're going to get a bundle of good features...
Regards,
RestorationRides
Sent from my Z981 using Tapatalk
