CAD delete, My way.
CharlieNorth
CAD delete, my way.
This is a little bit less work than what other guys do. The task is to simply hold the shaft out to keep the clutch engaged. Nothing more.
In this image the spring needs to settle in, it gets greased up for corrosion protection then a rubber boot goes over it.
This can be done with a machined plastic spacer as well,
No need to replace axle parts or housings.
  • Like
Reactions: plh
mbobhat
