hiphiker13
Hey guys, I love this forum and have gotten some great ideas from some of you for my last few setups but this is my first post. I need a little feedback on my latest project.
I have a 97 F-150 and a 060S Skamper pop up. They are both in great shape but the camper is made for a smaller truck. I saw how another guy on this forum with a larger Ford, maybe an F-250, built out his camper to fit his truck and did something very similar. I repurposed my old bed/drawer build from my basic camper shell set up and sat my Skamper on top of that and then built a couple of side cabinets to give it extra side support. I really like this set and feel like it works great. What I need some feedback on is how I tied the camper down.
First of all I used solid cast eyebolts with the highest load rating I could find. Then drilled through the bed and through the bed cross pieces as close to the frame mounts as I could get, and then bolted the eyebolts with metal plates and lock washers. In the front of the bed the cross piece was square tubing and in the back it was a bit thinner channel like piece and I used a small piece of 2x4 to take up space. From the eyebolts I ran chain and a turn buckle to the existing points on my camper.
So far I have driven it like this on the freeway with a pretty hefty cross wind, and also on a few short dirt roads in Death Valley. My truck barely notices the camper. The dirt roads had some wash boarding and a few spots were I would slightly pitch to one side. The wash boards seemed like no big deal but when the tuck twist, so to speak, I notice that the bed of the truck and the cab move separately, not a huge amount by any means but I can see it in my side mirror.
So my concerns are this: Are my tie downs sufficient? Is bolting into the bed cross pieces like this a good idea? Because my camper doesn’t hang over the bed very far it may be impossible or at least very difficult to put tie downs outside versus inside (like a happijack or torklift type rig). When the truck leans is it normal given the weight of the camper that the bed and cab "twist" separately? Should a worry about this twisting my frame? Are the bolts that attach the bed to the frame able to handle the load of the camper under typical driving conditions/what are their limits? Also given my set up what would you do differently? How have others built custom tie downs?
So far I am happy with what I've done, I worry a little but after my first trip it seemed to work fine. I have found no signs of damage or bending. I would much rather have it attached directly to the frame and will probably make that happen in the future, but for now this is what I have. I will take any feedback or comments it will all help, also if there is a tread on this subject I missed or any resource out there please let me know.
The pictures below should help make it clear how I've tied it in. Ask away if there is any other shots or info you think would help. Thanks guys!
View of the drawer notice the tie down on left
You can see the right side cabinet
Side cabinet, you can also see the turn buckle placement
Another view, notice the front turn buckle
Back tie down point, the front is identical. The 2x4 you see under the camp chairs is wedged in to help keep the under box from moving side to side, there is one on the left side too obviously.
Underside of back tie down point, on the right the black is the frame and the hitch, the 2x4 sits inside the channel
Underside of front tie down point (the left bolt), notice that it is along side the bracket that attaches the bed to the frame
