:iagree: and only because there is no "I'm with stupid smily"BajaXplorer said:If you bought the brake type axle, yes. A new axle prepared for brakes has a square plate attached to it that your brake backing plate bolts up to, then your old, or new hubs with brake drums will fit over the brakes mounted on the backing plate.
BX
airlaird said:OK, so to confirm...to get the M416 brake to work with a new axle....I need to get a new axle with capability for disc brakes???
airlaird
