fourstringfletch
For those of you with a G7 looking for a water/dust/smooshproof case, look no further. The G7 fits (just barely) in a Pelican 1010 case with some minor modification.
To do this you'll need to trim the rubber bathtub out keeping the edge of it as a gasket. I then used a dremel to carve out grooves for the hotshoe rails and where the inside radius of the case was too large - thereby bumping the bottom of the screen on the camera.
I also added a soft cloth to protect the screen from any grains of sand that may make their way in.
It's a good snug fit and is held in place well by the hotshoe grooves.
The loops on the case are great for threading a strap through on the outside of a backpack for easy access on the trail.
