Obviously, computer controlled EFI engines are my preference. I too grew up with Q-jets, Edelbrock, Carter AFB’s, Holley’s, Thermoquads, Motorcraft’s, breaker point ignition, etc. and I don’t miss any of that. I remember when swapping HEI onto older vehicles was like a huge technology upgrade. WOW, no more points to fiddle with!
- Drivability. EFI starts easy in all weather conditions, provides a smooth and instant throttle response through all power ranges. EFI always maintains stoichiometric air fuel ratio of 14.7:1 to optimize performance, fuel economy and emissions. Tune your carburetor in your driveway and it is already out of tune by the time you change elevations when you drive over the curb. I suppose if you live in the Midwest where the altitude is about 500-800 ft. everywhere this isn't much as an issue. But here in the West we could traverse over 7,000 ft. in a few hours. I live at 5,000 ft. but we often pass over peaks that are in the 12,000 ft. range. Or if we head to AZ we could drop a few thousand feet in elevation. How many times do you want to get out to adjust or re-jet your carburetor in a day? Carburetors don’t like altitude changes, extreme heat, extreme cold, bouncing or running off camber. When my truck about rolled several hundred feet off the cliff side of the Grizzly Lake trail in Chaffee County, CO because the engine would not stay running at the altitude and died every time it hit a bump or stepped on the clutch I vowed to myself to rid my life of carburetors. Have never regretted the upgrade to EFI.
- Reliability. EFI regardless if it is TBI or MPFI, GM, Ford, Chrysler, Toyota, etc. Gasoline EFI is very reliable with few durability issues. About the only thing that will really stop the vehicle dead in its tracks is a failed fuel pump or failed pick-up coil on those older engines still running distributors. Carry a spare if one is worried about a breakdown. I carry a spare fuel pump. Failed MAP, 02, CKT, or even a MAF are not going to stop the engine although it won’t run that great but at least it will limp you home or to the next part store. ECM failures are practically unheard of and are more times than not misdiagnosed as a failed than they actually do fail.
- Performance. Throttle response of EFI is unmatched by carburation. The engines will run upside down on a shaker machine until all of the oil drains out if you want them to. Even a severely modified gas engine can run extremely well with EFI when properly calibrated.
- Fuel economy. Fuel economy is always a moving target but on average you will see a significant gain in fuel economy with EFI over carburation. My personal experience has been the fuel injected big block delivers about 2 more MPG than the carbureted small block before it (adding an OD trans later added more). Something to be said for an engine running at stoichiometry air fuel ratio with the ignition timing computer controlled to keep everything running spot on. Did a TBI swap on a ’72 C20 a few years ago with very noticeable difference in fuel economy as well.
Computer controlled fuel injected gas engines are not an automotive industry conspiracy as some have alluded. It is a system designed to maximize performance, fuel economy, durability and reduce emissions and does a fine job of doing all of that. The jury is still out to see what fuel delivery will be like in a couple more years. We are in a transition time now where every manufacturer has at least 1 direct injected engine in their lineup. In a couple more years direct injection will be as common and port injection is today. The industry change from port injection to direct injection is huge. This is like watching carbureted engine go the way of the dodo bird in late 80’s as EFI took over. The next few years will be interesting. Hope this new technology doesn’t do to gas engines as what happened with new diesel engine technology. 2014 will be a big year for GM trucks. Like 1987 (First TBI) and 1996 (first OBDII SFI) all over again.
