Cascadia Vehicle Tent CVT 8' Awning Install on Four Wheel Camper FWC Hawk
Galvi5
I pulled the trigger on the CVT 8' Awning at the start of the month and just got around to the install this weekend. I was stalling for sure. I was not looking forward to drilling SIX holes in the camper. I took my time, measured 10 times and drilled only once per hole thankfully. I have a sneaking suspicion that the CVT and ARB awnings are made in the same factory at the very least. The aluminum mounting extrusion looks exactly the same on both, as does the PVC bag, poles, fabric, etc.
I had to fir the whole awning out from the sidewall of the camper using the stainless steel L-brackets that came with it. The reason I had to do this was to prevent tampering with the weather stripping and the channel it rests in. The weather stripping I am referring to runs vertically from the corner of the camper, all the way up to where the cabover extension meets the main body of the camper. The two L-brackets are intended to aide in mounting the awning from a Yakima/Thule roof rack. I cut the brackets into s semi equal sized pieces and two at each mounting point gave me the clearance I needed. Hopefully the photos show this. Otherwise, email me.
Obviously the camper is on a dolly but here are some shots of the finished product.
The L-brackets, cut down into 6 - 1/4" X 3"-ish "firing" brackets. Use a Harbor Freight cut-off tool and two wheels. The tool only shut off on me once, really due to overheating (reset button).
The bolts and, let's call them spacers, in the awning extrusion.
I drank a beer for every one of the six holes I drilled in this camper and it shows. You will see in one of the photos that I have "misplaced" a washer. I still have not found it and it cost me one more trip to the hardware store. FYI the black stuff you see on the bolts is the sealer that one of the many RV dealers in town sold me. The fella grabbed it off the shelf and told me it was the clear. When I saw it was the black, I said to hell with it. No one will see it.
The finished product.
Galvi5
Close-up of Spacers
These are the spacers in action. They had to be long enough to bridge the gap in the ridges of the aluminum siding material.
Galvi5
Exterior hole placement.
I did not get too scientific with my hole placement. I made sure to avoid the lifter bracket on the inside of the camper, but that was pretty much it. The two outside brackets are approximately 6 inches in from the outside edge of the awning extrusion...approximately.
In the above photo you can see the weather stripping that I was trying to avoid.
Galvi5
Thanks. I would have loved to get the Fiamma but could not come close to justifying the price. I live in Bend, OR so no delivery fee. $325 and mounting supplies was an extra $40. The sealer cost $15 alone!
brianjwilson
Some sort of lost...
Looks good! It almost looks strange mounted low, but obviously doing this allowed you to keep the roof patch in place. I see that four wheel camper normally moves that center latch forward for an awning, and usually it appears that the roof is bowed up in the middle as a result.
Galvi5
Because I have the "Thermal Pack" the roof would have definitely bowed. I was a little worried about the latch at first but there is plenty of clearance.
deadbird
Looks good. I mounted an 8 foot ARB awning the same way on my Grandby, but did not need spacers. I put those acorn head nuts on the bolts by the sliding bed part so nothing would snag or rip.
Galvi5
Gotcha. Great idea. I will be doing just that as well. Thank you sir!
How did you deal with the vertical weather stripping/seam at the front of the camper?
