CDN M101/M416 wheel sizing questions
Okay, just got a new M101CDN, and I've got a few questions about axle/wheel setup.
My goal is to get the same Nissan wheels on it that I have on my truck. I know the bolt sizing is 6x4.5. So is there just a wheel adapter I can find somewhere, or am I going to have to replace the axle?
I've seen a lot of people on here with these trailers who have outfitted their trailers with the same wheels as their tow-rig. How exactly did you go about accomplishing that?:arabia:
Normally, I would say it's very simple to do, and not that expensive. The M101 axle is a standard 3500lb axle with 10" brake drum/hubs and you go to a trailer supply and buy replacement hubs with the correct bolt pattern. Problem might be the Nissan bolt pattern. I could not find 6x4.5 pattern (6x5.5 and 5x4.5, but no 6x4.5). Did not look very long, but you get the idea, we change the hub/drum. There are places where you could get an adaptrer made I'm sure, if you can't locate replacement hubs (I just don't know of anyplace).
BX
http://www.redtrailers.com/ListItems.asp?cat=16
http://dexteraxle.com/hub_kits?start=0
Im pretty sure the Nissan bolt pattern is 6 on 5.5.
There are guys running Nissan wheels on their Colorados.
I think the new Nissans changed from 6 on 5.5, they could well be 6 on 4.5
If so there is no hub to replace it with you will need an adapter.
CoastalDefender said:
'05+ Frontiers, Xterras, and Pathys are 4.5
It's the bane of having such a great rig.
That blows!!
And here I thought I was having a rough time finding someone that stocks 3500# 6 on 5.5 idler hubs. Good luck.
I think at this point, it will end up being a lot cheaper to just get a spare stock tire/wheel from someone else who's doing a switch on their trailer.
Nobody wants to touch my mod for less than about $300.
Try checking out the Yahoo groups CDN2 M101 page. I am sure there is somebody on there with an extra tire and rim. If you check out my photo album under Feileod I used a toyota tire winch to mount my spare underneath the trailer. There is another photo album labeled spare tire mounts with some other helpful ideas.
Actually, I am planning on taking the spare under-bed mount off my Frontier and putting it underneath the trailer.
I'm getting a tire-carrier bumper for the truck here soon, so I can free up the space underneath for cool things like an Air Compressor and *hopefully* a secondary-fuel tank, so the chain/winch for the spare tire will go to the trailer.
And I would like to also add a spare tire mount (and spare) to the center rear part of my M101.
So I'm in the market for a set of take-offs from a M101 CDN. :victory:
I have heard of blank hubs. But never found them.
I know more than one person who has welded up a front hub on a vehical axle then just re-drilled the desired lug pattern.
Why couldnt this be done on a trailer axle?
2eleven
