Hello Folks:
Heidi and I need to do a field replacement of the low pressure fuel pump (located above the fuel tank) on Prima Terra II. Heidi is with the truck out in the backcountry and I'm in civilization sourcing a new pump without access to the truck, and when at the truck access to the pump is a bit tight, so I'm looking for anyone experienced the 2012 through 2018 FG low pressure pumps who could answer:
1. The power connections - are the terminals threaded & therefore require removing nuts to remove wiring, or are they a press on style? The drawings I have (see below) label them as "harness connectors" but I don't know what that denotes.
2. The input and output fuel tubes. Are the connections the same style as the fuel filter? The fuel filter connections require pressing a slight "button" perpendicular to the axis of the tube while simultaneously pulling to release the connection. The drawings I have for the low pressure fuel pump don't look like those connectors, but I'm uncertain.
3. If the two bolts that appear to clamp the pump in a circle of sheet metal are loosened, but not removed, will the pump simply slide forward or aft and be free, without removing the overall bracket holding the pump assembly to the frame?
I've attached the drawings I have of the assembly if those help jog anyone's memory.
Thanks in advance for your help.
Howard L. Snell
![523558 523558](https://expeditionportal.com/forum/data/attachments/426/426414-18b73360511a43f6b4a2d6cc55400f7b.jpg)
![523559 523559](https://expeditionportal.com/forum/data/attachments/426/426415-6db869ff5812d7c77db93ccdc61acf53.jpg)
Howard L. Snell
