tatuedrednek
Wanderer
Hey all! Thought I would post this up here and see if I can find some more advice. I have a 96 cherokee that has had a check engine light since I bought it. I have spent the last four months fixing everything that is remotely wrong with it, ie. leaks, etc. The time has come to diagnose my MIL, problem is, I can't get ANY scanner to communicate with the ecm. And to save my time and yours, I am a professional auto tech and am pretty sure I have covered all my bases. This thing has me stumped. All wiring from the ecm to the aldl (datalink connector) has good continuity, with the exception of one wire. I found the open in the circuit and repaired it. My ecm has all the proper powers, grounds, 5v references, etc. Even tried a new ecm to no avail. Did a bunch of research on the problem and all I find is problems with a sensor shorting out and causing this issue, but also causing a no start. My rig runs and drives just fine. Tested all 5v references to all sensors, no problems there. I can't be the only guy that has had this happen. If anyone has any ideas let me know thanks!
