I recently picked up a 2009 AWD 1500 passenger van with 28k miles on it, and have started setting it up for camping and passenger use.
Wheels and tires are Nitto Terra Grappler G2 265 /50 R20 mounted on Level 8 Tracker 20 X9 6-139.70. The bigger wheel helps the handling, and i will mostly be using the AWD in snow, and mild dirt roads, so i didn't wan much sidewall, or a lift at this point.
![20160909_180056.jpg 20160909_180056.jpg](https://expeditionportal.com/forum/data/attachments/291/291473-09d3bd29c65d9e01a9af9093c5e8b4f0.jpg)
The bed holds a full size bed I am using the Exped Megamat duo 10. It is a foam / air mattress, and has proven to be very comfortable. i like it better than allot of regular mattresses i have stayed on.
The sleeping bag I have been using is a Grizzly -25 2 person. It is very heavy, and is too warm for temperatures in the low 30's. We just ordered another grizzly 2 person 0 degree bag. If you want more details on the build of the platform and drawer, i have more pictures and can put together a more detailed thread.
![20161112_153255.jpg 20161112_153255.jpg](https://expeditionportal.com/forum/data/attachments/291/291472-29db51370d0a4c15d86e081cfc926567.jpg)
![20161116_202316.jpg 20161116_202316.jpg](https://expeditionportal.com/forum/data/attachments/291/291470-ea3dc8297e66e02d56e395641f985a54.jpg)
![Copy of 20161116_202244.jpg Copy of 20161116_202244.jpg](https://expeditionportal.com/forum/data/attachments/291/291474-3d40986134c0267bbac798680bf1c9b8.jpg)
![20161116_202254.jpg 20161116_202254.jpg](https://expeditionportal.com/forum/data/attachments/291/291471-d94e288e81e946c3c3ed0ce81ef66323.jpg)
Plans I still need some finishing touches on the plywood and a latch/ travel limiter. The next project will be to make some sort of curtains to block the light, and give prvacy, Idea's on this are welcome, as i havnt seen anything that i really like that much yet. I will probably also install a deep cycle battery and inverter at some point, and may do a roof rack/ awning. The build plan is still in the works, and i have been getting allot of good ideas from other threads on here.
Does anyone have any experience with a 12v heater? I am not sure if there is anything that could work well enough to heat the van in the morning, to make it easier to get out of the sleeping bag.
