I have something rolling around in my head, and at this point i believe it is possible, but i'm not 100% sure that it is.
My Thought: Putting an Express Body on a Suburban 4x4 Frame.
Suburban Frame will need to be stretched - due to wheel base differences
Steering may have to be adjusted a little bit
Body to Frame mounting locations may need to be moved around some.
Everything else will be little, such as wires, brake lines, and fuel lines being stretched as well, and the harness being dealt with.
As of right now, those are the only obstacles i could think of. I dont have any hard numbers as far as measurements at the moment, but i'm thinking with someone willing to try it (Me) it may be possible.
Part of the suburban frame could be spliced into the van frame as needed also.
Someone give me some feedback, on why or why not this is a possible or an impossible thing to do. The motors would be the same. So either it would be a pre LS (2002 or older) van matching with a pre ls (1999 or older) suburban. Or the other way around. Open to all ideas/criticism/exprience on this one.
FYI: i am seriously considering doing this. or trying to do what quigley does. I have a lift, welder, and all the tools and experience needed to make it happen if possible. I just have never compared the frames or taken measurements, but in my head i can see it working
