chevy wheels
will factory alloy wheels off of a mid 90's chevy fit an 08 tacoma? i know that they are the same bolt pattern but are the studs bigger, making the holes bigger than the tacoma studs? is the the tacoma lug/hubcentric? how about the chevy?
basically, will mid 90's chevy factory alloy wheels fit on my 08 tacoma?
thanks
jake
p.s. ordered a mv-50 air compressor today, any thoughts
buldyourown
I believe the offset is different, and I know that they won't clear the front brake calipers.
So no, you need Yota wheels.
FshTaco99
I had a guy give me a set of H3 wheels last week. I looked into fitment and someone said there is a problem with space around the hub.
EXP-T100
When I put Disc brakes on the rear of my 4runner I used Chevy 1500 rotors and if my memory servers me right I had to remove a 1/16 to an 1/8” to get them to slide over the toy hub. The Chevy hub is slightly smaller than a toy so factory Chevy wheels are not going to work, but after market wheel for a “Chevy” will since the manufacture will make one wheel to fit both (two birds one stone).
Clemtiger84
