Anyone mounted something similar? Im wondering specifically if I can avoid using the grille on the inside and mount the unit so it ties in with the existing rear AC ductwork? Im thinking the roof of the van wont hold the 100lb weight, or that the mounting will be unstable because of how thin the roof is. Normal installation looks to be 2x4 thickness in RV roofs, and I dont have that in the van. Id rather not build a bracing box on the inside, for aesthetic reasons. Anyone have better ideas or seen it done before?
Using the van for work, camping every night in between stops, all summer long. So AC is not an option, its absolutely necessary. I need something that can run off campground power each night and Ive located a used mach 3 unit for $200, but no mounting hardware.
