Coleman pump cup stuck inside lantern
ChadHahn
I replaced the pump on my Coleman lantern and didn't put the push on nut on tight enough. I pumped a few times and the pump came apart. The rod came out but the washer and godet are stuck in the bottom of the cylinder. What is the best way to get it out of there?
Chad
offero
Desert rat
I was searching for "coleman" in the equipment forum and found this thread, which nobody replied to so I thought I'd give this a go!
Option 1
Long tweezers, a flashlight, and beer for after you get the d*mned thing out.
Option 2
Disclaimer: I've never done this before, but it just might work if the pump cup is making a good seal. Drain the fount of all fuel and wipe the filler opening really well. Put the pump rod back in, if you can, and unscrew it a little to get the check valve open. Do not place the retaining bit back on though! Now clean the fuel opening again really well and try blowing into the fount really hard to see if you can push the pump cup out enough to where you can grab it.
Note: Make sure your neighbors don't see you attempting Option 2. That would be serious blackmail material.
Mcoleman
