Colorado Toyota re gear guru recommended installers.
Skinhyfish
Going to do it.. pull trigger on gears.. anyone had any luck with guys in CO who are reasonable and trusted at toyotas? I'm in front range but can travel for a good installer
2002 AC Tundra .
Thanks Zach
jsnow
Proffit's Cruisers would be my go to shop in CO. They are on the western slope. Otherwise Slee Off Road, or High Country 4x4?
Kya
I just had CODE in Rifle install my e-locker. They were easy to work with. In the front range I would look at Slee in Golden or Front Range Off-Road Fabrication in Ft. Collins.
Skinhyfish
I really don't know.. 4.88 was on my list but installer was trying to talk me to 4.56 because of 33's.. either would be good.. some have said only 200rpm difference. I just don't want to loose my highway function
TwinStick
I would say you won't lose your highway function, just need to slow down some. In our 4.56'ed Power Wagon, I have found that 65 mph seems to be it's happy spot, empty or towing, it keeps rear diff at around 175*F. The Hemi & G56 will certainly do much more, but the rear diff heats up a LOT more than @ 65. Most people don't give diff temps a second thought. I have got temps of 215*f+. empty, running @ 80 mph. Highest temp was 315*F when towing our 10,500 lb toyhauler on a 95*F day. I use an infrared thermometer & have verified it's reading with 2 other thermometers. Always within a few degrees of each other. I also use full synthetic fluid, always.
bkg
Addicted Offroad - Ft Collins. Scotty knows his shiznit.
Or just buy from ECGS - let them do the setup. Order, pay core, ship, install, send core, enjoy. I'm ordering mine on Monday. :)
JandDGreens
I have heard from several people that Colorado Axle and Gear is about the best in the business. I just haven't put together the funds for lockers and gears yet.
TNielson-18
