Compact Camping/Toyhauler
Blderman
I custom built this small, off road camping trailer about 1.5yrs ago. I took a 4'6" x 96" Snow Bear trailer, beefed up the tongue/frame with 1/4" x 4" steel angle, added a brand new 3,500lb axle and mounted Jeep Wheels/Tires on it with square fenders. (Has two spares wheels/tires) The exterior is clad with white FRP, PVC trim and aluminum. The roof is a single piece of EPDM with (3) coats of white elastomeric paint. Has a single 14" x 14" roof vent and (2) 4" intake vents near the floor. Large, 50" x 60" rear lift up door (needs gas springs to hold it up) If you have a way to remove the POD, the trailer doubles as a utility trailer and I will include the sides and tailgates for it. This is still a work in progress (IE: needs final caulking, trim, misc details) but is very functional as is. Will sleep two adults on the floor and a small child on the upper shelf that I built. Weighs 1,650 empty so it can be towed with any SUV or small truck. Floor is insulated and has vinyl tile and carpet. Interior walls are unfinished, I planned on leaving them that way as it provides more utility. For reference, I can load all of my camo, meat packs, target, bow case, calls, boots, sleeping gear, water, coolers etc and still have plenty of extra room/weight capacity; for it's size it will hold a lot of gear. A mid-size ATV or (2) dirt bikes will also fit if the interior shelf is removed.
Only reason I am selling is so I can build another one....had a lot of fun building this one. Priced reduced to $800 OBO, this is less than the material cost to build it. Please email- bowhunter97023@gmail.com or call/text 503-201-5718. Located in Portland, OR.
Photo Aug 09, 8 50 47 PM.jpgPhoto Aug 24, 5 40 53 PM.jpgPhoto Sep 30, 4 28 53 PM.jpgPhoto Sep 30, 4 29 20 PM.jpg
4xCoffee
