Trying to figure out what tires I want for my project. The MPT 81's seem to fit the bill. First question; Do you need beadlocks or special rim shape to use these at low (20 psi) pressures? I will be putting these on a Dodge 5500 so i will need custom 10 lug wheels with custom back spacing. Second question; I looked at the Conti tech data and i'm confused by the sizing data. it says the 275 has a 440 mm radius. This converts to a 34.6 inch diameter. But the 275/80-20 designation calcs out to a 37.2 in diameter, which is right?
Any comments on personal experience with these tires would be appreciated.
