Coolers
Just a vote for the Metal Coleman coolers. I get good performance out of mine 3-4 days with Ice. Keep it shaded, minimal opening,make sure items are cold to start with and don't commit the cardinal sin of draining the water. leave it be.
Wow - in my personal experience I've always found that draining the water made the ice last longer. I used to pull a trailer (Reese Transporter) behind my motorcycle and had drilled a hole in the floor of it so the cooler was always draining via a hose. Using block ice it would last *days* longer that way.
I wonder why our experiences differ?
:beer:
:beer:
This is definitely a hottly contested subject pardon the pun. your right the ice does last longer but that doesn't mean the air in the cooler is colder. The air actually stays colder with the cold water in the chest keeping things colder. So if you want to keep Ice longer drain the water. Also you are using block ice which has better staying power than the bag stuff which introduces more warm air in the mix. Different scenarios call for different tactics. Let's say I'm going out for 3 or 4 days with no opportunity for a refill. If I fill up with Bagged Ice, I dont drain the water, I just make sure everything is in waterproof containers.
Hmmm sounds like a good suggestion for the Mythbusters to investigate LOL.
I've used plastic sided coolers. Never paid extra for the metal sided ones since I don't put my coolers through anything that would require extra protection in it's sides. I would think the metal ones don't provide too much additional cooling though
I do ensure that all 6 sides are insulated especially the lids. A lot of buyers make the mistake of buying a cooler without an insulated top.
Block ice has worked the best for me including a late April Moab trip where the block lasted almost an entire week.
HTH
Cool. :)
I never considered the air temp... just focused on the ice. lol I've never had a problem with it not being cool enough so - in my experience - I'll likely stay with cool enough and as dry as possible. Nice to have drainage holes in the floor of my Jeep. haha
:beer:
In my experience, it is more about ice and cold air management than the price of the cooler. Heresy I know, but thats my observation over the last 50 years or so, much of it long before 12v compact refrigerators were available, and most of it before I had one.
My suggestion is to try any appropriately sized, moderately-priced, brand name cooler, marine or otherwise, plastic or metal. Buy a max cooler if you can find one on sale - there is more insulation in a max cooler than the average cooler.
In my opinion, while metal-jacketed coolers are desirable, the metal is more for protection and aesthetics than insulation (except perhaps for the high-end specialty coolers), the primary difference between marine and other coolers is color and the "fish ruler" on the top, and brand name coolers have competitive performance features at each price point (i.e., sometimes the similarly priced cooler really is better than the one next to it on the shelf just because it is red or clad with shiny stainless steel).
I think it is better to have two smaller coolers than one large one. Not only are two smaller coolers easier to shoehorn into a rig, having two coolers assists with "cold managment."
If you have frozen food, pack it with dry ice in its own cooler if you can. If you must mix frozen and non-frozen perishables, you can try sandwiching dry ice on the bottom, then newspaper, frozen food, more newspaper, with sealed bags of regular ice and the non-frozen food on top. [Experiment - sometimes milk and lettuce freezes with unhappy results.]
Block ice will last far longer than cubed or crushed ice.
I keep drinks in a separate cooler to keep from losing cold air and ice in the cooler(s) filed with perishibles or frozen food (which should only be opened at mealtime). A small cooler is great for this because it holds what can be consumed in the short term. I have found it pointless to waste precious cooler space (and ice) on beverages no one will consume for several days.
In the same vein, coolers should be kept closed as much as possible. Know what you want before you open the lid. Preserve the cold air as much as you can, as it takes considerably more energy (translate: melting ice) to cool air than it does to maintain an existing temperature.
Oh yeah, you can prevent soggy food in your cooler by keeping wet ice in sealed bags or plastic containers and conscientiously using resealable plastic bags for all food items.
I have learned each of these lessons the hard way at one time or another.
And all that being said, I like Coleman.
I know fridge units are the popular way to go but I am wondering if any of you have any opinions on coolers? Most seem to do the same thing but some advertise "will keep items cold for 5 days". Thoughts? Good luck with a certain cooler? Does the metal Coleman cooler really work as they say?
Any info for those of us that don't need or can't afford a fridge :)
Thanks,
Jordan
I've been using a Coleman Extreme cooler for a couple years ago, and it definately works well. I go four to five days betweeen stops back to syphilization, and have ice left over. I store everything in Snapware containers to keep the contents dry.
I also leave the water in the cooler between resupply. I use a min/max registering themometer to moniter the cooler, and I've never seen it go below 44F, even in hot weather.
I'd sure like a nice 12V fridge, but I don't have any issues with my cooler, so I'll keep using it.
The Max/Extreme coolers work very well.
You definitely need block ice.
What I do to make manageable blocks of ice is thoroughly rinse out old OJ/lemonade cartons and then fill 'em and freeze 'em...
It's cheap, effective and the blocks are just the right size.
When loading for an expedition, simply rip off the waxed cardboard and you have a lil' glacier for your journey. They last about 4-6 days in a good Max cooler.
I have to say in all this. Although I have a metal Coleman and have had it for a long time. I don't believe if I were to ever by another cooler it would be the same. I have friends that use the cheaper Coleman extreme or maxcold (cant remember) and have great success.
I've had very good experience with the plastic Coleman Extreme. The food cooler will hold ice out in the Mojave for four days for the first two years.
After two years their performance starts to decline. I guess the lid to body seal starts to go. So every two years I grab a couple more during the annual Big 5 sale and sell the old ones off for a few bucks.
Galaxy cooler
I placed an order with galaxy for two coolers. When they get here i will post a report on how well they do. I was going to by a Yeti but found that Galaxy is still selling coolers, and they are way cheeper than the Yeti, I thought I would take a chance on them.
I have a waeco cf50 frig, but it is not always convient to use it. so that is where the quest for the better cooler comes in.
Any updates on your experience with the Galaxy coolers? Which ones did you order?
I've been considering either the 80qt or 60qt cube cooler.
Something that will help all coolers keep ice longer is a insulated "blanket" inside the cooler separating the ice and food from the air inside the cooler. You can easily make one from a piece of insulation or foam sleeping pad cut to fit inside. Having a beverage cooler AND a food cooler also helps, opening the food cooler only once or twice a day letting your planned meals for the day defrost in the warmer beverage cooler. Freezing your cooler before a trip also helps, once loaded, put it in a chest freezer (or walk in) for a day or two and keep it shut as long as possible.
I've had good luck using Marine coolers and Extreme type coolers keeping ice at least a week, But I was planning a longer trip I'd break down and buy a Yeti cooler. Several friends have them and have nothing but good things to say about them including having cold food and beer at the end of a 21 day Grand Canyon raft trip.
I noticed my cheap Igloos top was hollow. I drilled a hole and filled it with expanding foam. You know that "great stuff" brand for filling gaps around windows. It can be a bit messy, but quite fun. My very unscientific experiment seemed to show an improvement. Also the lids on cheap coolers dont usually fit fell. A little hinge or latch tweaking and some rubber gasket material could help.
I think I may add a blanket. That seems like a smart idea. Something reflective, kinda like windshield shades but fabric like. Any ideas? Sew together the four sides, one side of the lid and an overlapping velcro, or magnetic flap...
Fj89
