Critique my design... 4x6 trailer with RTT
McManusR
I'm in the process of designing an "overland" trailer, and I'm looking for some feedback on my design so far (material choice and frame layout) as I want it to be durable, but not a PIG.
I don't plan on taking it anywhere crazy as I drive 2WD Tacoma so mostly gravel/forest service road travel. My goal is to have a self contained kitchen, on-board water, with a rooftop tent. I plan on possibly adding a removable rack for our kayaks over the tent. (not in the drawings) I plan to use Timbren axel-less set up in either 2000# or 3500# with brake (We tend to travel lots of highway miles so I like the idea of having brakes, which would be an upgrade as our current trailer does not have them)
My first trailer was built on a 5x8 bolt together frame, and is 90% wood construction, but for this I'm looking to jump into framing the structure in metal which is new for my hobby skill set. My brother in law is a welder, but he mostly builds from engineer drawings so he is limited help for the design and I was looking at buying a welder so I'm not 100% reliant on him.
Not sure on the skin material yet, I like the idea of painted aluminum but need to find a source.
Let me know if you have any questions, or feedback. Thanks!
Overland v2_001.jpg Overland v2_002.jpg Overland v2_003.jpg Overland v2_004.jpg Overland v2_005.jpg teardrop.jpg
old_CWO
It still looks overkill to me. Maybe 2" square .120 for main frame rails? Center cross members can be angle vice tube, and I would only use two. With your tongue design I would also consider square instead of rectangle tube. If you think about it, a junky Carry-on angle iron trailer would easily do what you're asking. You probably only need modest improvements over their design to achieve a significantly stronger trailer that doesn't weight a ton.
Looks like fun, enjoy.
TNielson-18
