Betarocker
Hello. Please critique this diagram. For Baja Designs LP6 (1 pair) and LP9 (1 pair) lamps. The Diagram is for one pair of lamps. A second exact one for the 2nd pair of lamps.
A few notes.
- Low beam power must be off when high beam is powered. Warning on manufacturer's literature.
- DRL must turn off when high or low is powered to lamps, Causes back feeding and flickering if DRL has power and either high or low circuits energized. Found this out when tried wiring to manufacturer's basic diagram.
- Want to use vehicle's high beam circuit to control LP6/9 lamps. I don't want to be flipping 8 switches when need to dim to low beams
- Want option to shut of DRL if not wanted (dark mode)
- Want option to only use vehicle's lamps (no LP6/9 on with high beams)
- The Hi-OFF-Lo switch is 25A rated; higher than current when lamps produce max load.
- Want the DRL to turn of when key is turned off. I haven't found a dedicated circuit which would trigger when vehicle shifted out of park.
- Wiring will be 10 awg from battery until it splits before the H-O-L switch, and then 12 awg. Only the DRL circuit and trigger circuits are 16 awg.
- Trying to keep most everything inside the cab.
Vehicle is a 2016 Ford F350 4wd diesel.
Many thanks.
Julius
A few notes.
Many thanks.
Julius
