Custom Four Wheel Camper "Hybrid" Build
NorthernFocus
FWC BUILD DETAILS….
Custom Four Wheel Camper (For Sale) : Price: $27,950.00 USD (OBO)
2017 FWC showroom "shell" model/ purchased in 2019/ built out in 2024
Base Model, Custom “Hawk”
Custom Build Out
920 lb dry weight / 1,200lbs wet weight approximately
DINETTE / LOWER BED
Custom Front Dinette Table
(large) 40 3/4” (L) x 23 3/4” (W)
converts into lower bed 77 1/2” (L) x 32” (W)
Comes with 4 cushions to make up the lower bed
UPPER BED
(Double 77 1/2”x 49”) with German Froli “Star” Spring System (added comfort & condensation reduction)
expands to 77 1/2”x 65.5” for full size bed w/o Froli
INSOLATION
FWC “Arctic Thermal Pack” added to inside for better insulation/ cooling
LIGHTING
3x LED roof light strips (Installed by FWC)
ROOF RACK
Yakima (Tracks Only)
WINDOW
Large passenger side (emergency exit window) with screen. Small back window beside door (non opener)
FAN
Rear 12volt Power roof fan 3 speeds in both directions
STORAGE
3 Red OXX MFG Soft Bag sold by (OEV) for clothing etc/ organization (huge weight reduction over cabinets)
3x Front Runner “Wolf Boxes” for dry food, etc…(2 have custom wood tops that provide a flat surface)
Custom Aluminum upper side boxes (full length (7ft ) w/ locking hinges. Door opens down to 90 degrees and makes a usable table for cooking or working surface.
STARLINK (Sept 2024)
-TRIO Flatmount (GEN 3 Standard Speedmout) (white colour with Rubber coated Magnets & VHB Adhesive Podwer Coated)
-Gen 3 All In One 12V Conversion Attachment (Standard cable length wired thru FWC driver side rear wall) formally solar panel outlet to avoid extra holes.
“PLUMBING” (New 2024)
Boxio Toilet/Sink (Sanitary Kit)
SOLAR (Professionally installed by RV dealer in Sept 2024)
Roof mounted 2x 200 watt ridge solar panels (Brand: Armada Solar, 25yr warranty)
Bolted into FWC Yakima tracks
POWER SYSTEM (Professionally installed by RV dealer in September 2024)
Canbat 12V 300Ah Cold Weather Lithium Battery (LiFePO4)
Blue Tooth Chip added to monitor via app
Victron Orion XS 12/12-50A DC-DC battery charger (New in 2024)
Victron MPPT Smart Solar 100/30 (New in 2024)
Canbat 12V 40A Lithium Battery Charger (LiFePO4); (New in 2024)
Blue Sea Water- Resistant Accessory Panel New in 2024: (New in 2024)
Circuit Breaker (15amp), 1x 12-Volt Socket, Dual USB charger & Mini Voltmeter
GoPower PureSine Inverter 1500W
FRIDGE FREEZER (Purchase in May 2024)
Engel MT-45-U1CD-P (40 liter/ 43 Q) Dual Voltage (12-volt socket or 120v wall outlet)
Engel MT-V Transit Bag cover for protection & insulation (New 2024)
ARB Steel Fridge/Freezer slider bolted thru camper floor
HEAT (installed by RV dealer in 2024)
Espar D2 Diesel Heater
Rotopax Exterior wall mounted fuel container (yellow) 2 Gallon with Rotopax locking system (New 2024)
Espar D2 Basic controller mounted on interior wall to control heater On/Off & Temperature climate control.
PROPANE (New 2024)
Exterior mounted 13 Lbs LP container
GP Factor Lockable LP holder
Mule Outfitters Aluminium Accessory Panel bolted into FWC Jack Brackets
OTHER
Bag Awning; Covers Passenger side/ Rear door; Alu-Cab Shadow awning 270 “batwing” mounted on MULE HD Aluminum Shadow Awning brackets (New 2024)
2x Front Runner Expander camping chair with protective cases
Regular HD Aircraft Grade L-Track w/ Universal Mount used throughout camper to secure items while off roading and strapped down using Front Runner Stratchit Tie down Straps 5x
Camper Tie Downs; using Eye bolts thru flatbed on aluminum plated “washers” lock nuts, above tray “Torklift” Basic Springload Turnbuckle Kit in 4 corners
4 Stratchet tiedown straps for interior storage boxes
50lb Front roof struts added to the camper to handle the added weight of solar panels. (New Sept 2024),
30lb Rear roof struts are standard from FWC and unchanged.
NOTE:
Camper does NOT come with camper jacks (Rieco Titan) Mechanical Camper Jacks, 2000 lb capacity
Issues with Camper
-“Roof Pinch” occurred while lifting roof while one latch was latched down. Location on passenger side, middle position (cosmetic not structural) roof still laches tight. Can be easily fixed.
-Rear Door shifting with screen door rubbing on frame slightly. Door still functions “normally” just something that needs to be addressed at some point.
-Roof has minor dents and scratch’s due to hail and ice freezing. Roof is 100% water tight.
-Back wall “porch light” needs work as connection inside has been compromised and contacts needs cleaning. Light housing exterior will then need to be resealed. Minor fix
-Some light rust on latches and on rear exterior lifting gas struts (factory 30lb load lift), Front Structs a new (2024) 50lb load lift)
Email: http://northernfocuscreative@gmail.com (for more info or pictures)
jacob_lashell
