Custom full size overland trailer build
GTPD205
Veteran traveling for mental stability
Custom Built Overland off-road trailer for full-size vehicles.
The build was custom designed Heavy Duty trailer to be pulled by my full-sized truck. Designed and built for overland use.
It was designed to accommodate a family of 5 and two dogs. My family and life have been downsized and I no longer need a trailer this size. It is professionally designed and built by a union fabrication shop (family owned). Unit is structurally sound and ready to be completed by you to accommodate your travel style. The trailer has amazing ground clearance and storage room with compartmentalized areas. Designed to include pull out galley with sink stove and refrigerator, shower unit, batteries and solar, rooftop tent, tools and generator. Area for wet clothing or camp gear to air out while traveling. You can customize these areas to fit your needs.
Located in Southern NJ $7800
Features include:
Over 158 cubic feet of storage. Main compartment is 65.18 cubic feet.
18” of ground clearance at center.
Powder coated black.
Stainless steel fresh water tank (37 gallons).
Locking compartments for security.
35” tires with Electric brakes and spare tire mount.
Stabilizing legs.
Hat channels for mounting slide systems.
Reinforced roof for handling equipment loads.
***Lock and Roll hitch assembly, https://locknroll.com
***Timbren Axle-less suspension system, 5200lb https://timbren.com/axle-less/
Supreet.dhaliwal
