D-Rings on factory recovery points Gen 3 Montero
earljuic3
Does anyone know the best way to go about putting d-rings on the factory mounting points on the front end of a gen 3 montero? Would isolator washers like they use on Jeeps to reduce rattling stop the d-rings from rolling over in the loop?
Inyo_man
Don't piss down my back and tell me it's raining.
I've seen a few folks that have packed the pin out to keep the shackle from moving too much and rattling. It seems to work well to reduce the rattling.
Personally, I don't drive around with shackles in place. I've never had an issue with shackles "rolling over in the loop" due to the fact that 3/4" shackles will only allow the pin to pass through the factory loop. I suppose if you're using 5/8" shackles, then side loading the hardware during a recovery would be a serious concern.
jeep-N-montero
Bungee cords are your best friend when reducing noise/movement of clevis shackles or anything else you wish to use on the front bumper, I did this for years but now I usually remove them when not needed.
earljuic3
thanks for the input guys...as much as I want to be the cool kid and have them hanging off the front all the time I think I am best served just putting them in the truck lol.
jhill15
Here ya go man,
I used 1/2 inch washers from lowes so they would hang straight. Mine do not swing and hit the front plate with the washers
jeep-N-montero
Another reason to remove them when not needed is mud and rust can do a number on them, not to mention theft happens.
Inyo_man
If you do like your shackles on all the time, I've seen folks who use a hitch pin or zip-tie to keep the pin from vibrating out.
Over tightening the pin to keep it in can cause the pin to get rusted/crusted in place, which makes it difficult to remove.
Sabre
Overlanding Nurse
Yeah, I'm not so sure that hanging a couple of shackles on there full-time would make anyone look cool. It's like leaving a high lift jack on the truck when you're just commuting or going to the mall.
montypower
Adventure Time!
Agreed. Bad idea to leave on all the time. Noise, Wear and you have to remove them to use anyway. Maybe for looks. But who owns a Montero for looks?? Just sayin'
granitex1
The biggest problem is that those are not recovery points, all that they are is shipping points. They were never designed for the forces involved in a proper recovery.
Toasty
You would be incorrect.
I'm going to have to agree with granitex1, all the factory tow points are really weak. I've seen them bend, break and straighten out from being pulled hard. I kind of recall someone going to the dealer with their truck and failed "recovery" point and told it wasn't meant for that. Probably a write up on the 4x4wire about it.
On the Gen 3 it may be different because they're unibody but I wouldn't chance it.
jesus m anderson
