Selling new/never used 100AH LiFePo4 lithium battery.
I imported two of these models: http://www.deepcyclesystems.com.au/...le-battery-charger-trolling/12v-100ah-lithium but only need the one.
I got this model specifically to run in engine compartment of my FZJ80. DCS owner Paul said he specced this battery for that exact usage with a BMS set for a slightly higher temperature range than typical.
I'm using the other battery in accessory battery slot in my rig and it works amazing - runs within temp specs, my last 40+ hour camp with fridge, lights, etc., drew it down 33% (these can be safely depleted way lower/more often than AGM) and it was back to 100% within 20 minutes or so of starting my truck.
More info and blogs from Paul here: http://www.deepcyclesystems.com.au/...etailed-analysis-of-under-bonnet-applications
Asking $980. Pick up in Santa Cruz, Ca, or will ship on your dime. Thanks.
