double moo
My son brought back my Trooper after this weekend claiming that the winch wouldn't work. They had used it to get unstuck and spooled the line back in - then once home tried to unspool the line and re-seat it like they should have immediately after the use.
So I go out and sure enough there is nothing happening. I popped the hood and found an ugly mess of the battery. It looks as though the battery got loose and shifted just enough to contact the side termminal where the winch was connected... yes I said was.. to the battery hold down rod. This appears to have caused it to arc weld the terminal to the rod, actually cutting through the rod, and continue arc'ing until it melted the terminal lead out of the battery.
(The hold down rod shown was swapped from the other side)
The other possibility is that the terminal overheated from the winch use and melted itself out - contacting the rod before faling free. I am assumming all this because I have'nt another explanation nor the experience to tell otherwise. (the winch worked to spool in the cable after the recovery... two days later no workey)
In addition to this... I tried hooking the winch up to the useable terminals on the battery and it would just click, like the solenoid isn't throwing... at least it clicked several times until it started smoking and some heated liquid dripped out - which is when we noticed the smoke and disconnedted everything!!!
Cool thing is that the battery still holds a charge and starts the truck like nothing happened! I got out the voltage tester and confirmed that the battery is holding 12.2 volts static, with 13.6 showing when running. I'm hoping that this indicates that the alternator is OK -It should read about 14 when charging but it has read a little low since it was installed a year ago.
So... Am I on the right track? what else should I be looking for? And can a smoking/leaking winch be repaired or do I start looking for another? Any suggestions are really appreciated.
Moo
Moo
