MuskokaMudder
World Explorer
What methods are used for dealing with moisture in these rigs? How do you deal with Cold weather travel?
Dehumidifier
Run AC
Live with it?
Thanks
Dehumidifier
Run AC
Live with it?
Thanks
Insulation
Heat
Ventilation
The insulation and how it's configured - deals with wall/ceiling/window condensation. Cold paths through window trim and on insulated windows themselves will be an annoying source of condensed water in the camper envelope even in well insulated campers. Also any hatches in the ceiling will drip from condensation so place them accordingly...The amount of nuisance condensed water will depend on the your heat & ventilation.
The more ventilation you have the more heat you'll need. Ventilation is pretty straightforward - open a window - but the type of heating makes a difference. An inexpensive catalytic heater is the worst for condensation - they actually add moisture to air. An outside vented forced air heater is better & a diesel fired hydronic heated with water/air heat exchangers and a radiant floor circuit is probably optimal for cold weather livability.
The overall camper design comes into play as a poorly insulated camper with limited ventilation to the closed storage spaces will become a moldy mess if "put up wet" after a winter camping trip.
In a typical production camper one way to go is heat as little as possible for sleeping (I hope you are happy in a sleeping bag...) and use full heat just for eating & a bit of comfortable hangout time. The idea is to make sure the camper & bedding don't get progressively wetter...Because the condensation in a typical production camper can be astonishing under the worst conditions. My favorite cold weather mod is a blower with a hose from your truck cab to the camper so your engines waste heat goes to heating & drying your camper - with the huge added benefit of supplying enough added air pressure to the camper envelope to keep all that dust from sucking into the camper. Moe
Andre - Without knowing what kind of camper you have, your budget & your desired comfort level it's pointless to do more than deal with generalities...Judging by your location you have a serious cold weather situation which suggests a serious solution/mitigation. Doesn't have to be expensive but all the solutions/migrations are rig specific...and no rig is mentioned...
"anyone weigh in with additional methods to eliminate thermal bridging?" - post build? No, at least I can't think of any. In the design phase there are many ways to eliminate/mitigate thermal bridging.
and thoughts on vapor barriers?" - A camper isn't a house & it's a rare one that isn't far more "vapor barricaded" than a house. The issue is human produced wet vapor and when it condenses on a cold interior wall, window or metallic window/door frame. A campers small interior volume combined with the inconveniently large breathing mammals within cry out for breathable exterior walls - not vapor barriers... I mention breathable exterior walls only as a...hypothetical solution...at least until an insulated/structural Goretex is invented. Moe
..... and thoughts on vapor barriers?" - A camper isn't a house & it's a rare one that isn't far more "vapor barricaded" than a house. The issue is human produced wet vapor and when it condenses on a cold interior wall, window or metallic window/door frame. A campers small interior volume combined with the inconveniently large breathing mammals within cry out for breathable exterior walls - not vapor barriers... I mention breathable exterior walls only as a...hypothetical solution...at least until an insulated/structural Goretex is invented. Moe
Very helpful, IanI looked a insulation, condensation etc when building my truck, like everyone has said, main cause of moisture is people ( unless you are boiling lots of water for tea constantly. The only way to reduce condensation is through ventilation. If it is very cold outside, then you need to heat up the air coming in and let it out somewhere. All the insulation in the world won't help is you have created your own sauna. .
As an example, I used to run a concrete lab, inside it was around 90-100% humidity, 26 degrees C. If someone opened the big outside door in winter ( 5-10 degrees C), cold air would form "clouds" and it would rain inside our lab![]()
I have a number of cold bridges which I could not avoid, the main one being the legs of the rear seats, which needed to be steel and part of the overall frame in order to get the certification for the seat belts for rear passengers here in Australia. It will be covered with a wood trim, but I expect it will be the main source of condensation but we will just have to live with it. In cold weather we will have block of the crawl through, otherwise the cab windows and windscree will be constantly dripping, nothing we can do to insulate them
We have a 9kW diesel heater, and out camper internal dimensions are 1.9m H x 2.0m W x 3.3m L. so 12m3, with about 20% taken up by furniture, so lets say around 10m3 of air space. Our 4 fans are capable of putting 200m3 per hour through the heat exchangers, so we could be changing the air around 20 times in an hour if the heaters are capable of keeping up with that volume, 9kW is a fair bit of heat. I used this graph http://www.chromalox.com/catalog/resources/technical-information/Heat-Loss-Calculations-and-Heater-Selection-Air-and-Gas.pdf to work out that we needed 5kW of heat to heat up the 100cfm approximately from -20 C to + 25C .
Probably not the right way to do it, but should be close enough. It looks like if the camper is warm, from driving around, we should be able to keep it warm, and fairly dry as well. Like all things time will tell if I got it right.
I am not sure if this helps you, but I leave a bucket of charcoal in the back of my truck, it does a great job of absorbing moisture.... then when camping I burn it and get new charcoal.
this seems a bit confusing. my understanding is that a vapor barrier controls where the moisture is allowed. wouldn't a vapor barrier applied to the heated side of the insulation contain moisture so it could be actively disposed? (in theory - fan/ open window)
if moisture is allowed into the wall cavity, what happens when it reaches the inside surface of the vehicle's outer skin? and on a hot day parked in the sun, is this contained moisture driven back into the cavity only to condensate on the wrong side of the vapor barrier? molding, and eventually rusting out the rocker panels (in the case of a van)?
