Defender 90 drawer build (Pic heavy)
Dozer Dan
I needed a drawer for the back of my 90 and none of the commercial options appealed to me. Sure, some were nice but none utilised the space particularly well. So after a while of thinking, drawing and planning I had come up with an idea.
Started by welding up a frame for the drawer runners.
Painted and test fitted
The runner in place as well
There’s a hump in the door and to maximise the space I mounted the runner over it
Using the existing holes in the tub
18mm sheet of plywood
And a smaller piece on the other side
The join is both tight and well supported
Measure twice…
Starting building the drawer
First test fit with all the sides of the drawer fitted
Filling the little gap for the hump in the door
Adding the paddle latch.
First coat of paint
Glueing down the carpet
Adding lino edging to the sides
This is a very important structural brace. As the piece of plywood on this side is only screwed down on one side - And the fridge is bolted on to this piece of plywood it would be flopping about otherwise
And there we are, everything in place
I couldn’t find a good nosing locally so I had to order one
Great work! If I didn't like sitting on the wheel "humps" so much I would also probably install a drawer system. I keep my rear bench out and run my 90 as a 2 seater always. My Boxer loves the back and when the weather is bad, we sit in the back and enjoy our drinks out of the elements.
Wow, incredible job matching the vehicle. What kind of glue did you use for the carpet and where did you get the aluminum trim for the edges?
Thanks for all the positive comments all.
I used regular PVA glue throughout. I just rubbed the back of the carpet with sand paper to give it key first, that carpet is not moving.
The aluminum trim is just lino-edge or vinyl-edge used for lino carpet, just from a local builders providers. At the back there's a stair nosing. I couldn't find one just right locally so I had to got that online, ebay I think.
Jlbeats
