peakvehicles
Hi all. I was tired of the diesel smell in my tool box and wanted to add a bit more capacity for winter trips. I came up with a pretty clean install idea using a diesel roto can.
I used a high quality name brand pickup tube from ebay. Because of the center boss in the tank I had to do a two piece pickup tube so I put a slight flare on the ends of the tube. Use a piece of string or welding wire to pull the pickup up through the hole.
