Diesel Heater...Relocating control panel???
Rbertalotto
My understanding is the thermostat for the ALL IN ONE Chinese diesel heater is in the LED display panel. Makes no sense that this thermostat isn't inside the RTT or camper while being used.
Has anyone relocated this panel on a linger wire to be located inside the tent?
jeepers29
This is a great question. I can't imagine that it would be too hard to do, but waiting to see if anyone has attempted.
mrjosh
Cut and extend the wires by either crimping or soldering. I soldered mine and added about 8ft so the controller reaches into my RTT.
Rbertalotto
i just did this with a 20" piece of stranded telephone/data cable. works great! i tested it by setting the controller 10 degrees higher than ambient temperature and then used my heat gun to raise the temperature of the LED control panel. Heater cycled perfectly. Should make a huge difference in the comfort of my RTT
pictures here
Smithmds77
