Diesel powered JEEP, lifted, ready to run
Hawkz
What hood?
Do you have any pictures showing how much room there is between the oil pan and front axle?
haven
Here's the ad, which the OP was too lazy to cut and paste. Asking price is $10,500 for a 2001 Grand Cherokee with am Isuzu four cylinder diesel engine.
Selling 2001 Diesel powered Jeep Grand Cherokee WJ. The jeep was originally a 2wd laredo model and has been converted to 4wd using a stock front d30 axle. The original 4.0L engine was knocking at 92,000 miles so it was pulled and an isuzu 4bd1t diesel engine was installed. The drive train is all very heavy duty and professionally done.
Interior is a 9 out of 10, exterior is 8.5 out of 10.
Below is a list of all that was done.
2001 Jeep grand cherokee laredo WJ model
Clayton long arm 4" suspension lift
converted to 4WD stock axles 3.55 gears
265/75/16 cooper tires 150 miles on them, still new
Isuzu 4bd1T diesel engine rebuilt with 45,000 miles on it, custom 370cc injection pump ($3500 new by itself) custom 5X14 injectors $800 new both from shied diesel performance, custom valve springs to spin the engine at higher rpm if needed, HE351 turbo, custom serpentine belt drive engine is approximately 350hp at the rear wheels
2005 4L80E transmission with performance rebuild and custom converter roughly 125 miles on it
BW4401 transfer case, very heavy duty only came in 1ton truck models
3.5" exhaust
custom 4" mandrel bent intake
Large top mount intercooler
The jeep is complete and drives very well. Engine is very powerful. Not sure what kinda mileage it gets haven't drive it it enough.
Looking to sell for $10,500 or trade. Any questions call or text me at XXX-XXX-XXXX
carcrafter22
Gee sorry if I was too lazy to paste the original ad, I wasn't aware it was so difficult to click a button.
The original hood is uncut, it would need to have a hole cut in the center and have a hood scoop installed for it to shut all the way. Right now the hood is off and in my shop.
I don't have any pics of the axle to pan clearance right now but I will try to get some. I can tell you the oil pan was modified to clear the diff and has roughly 1.75" of clearance with the axle hitting the bumpstops so no issues there.
twinsprings
I pushed the button, too. It's good when the cut and paste includes pictures, for reference after the ad ends. Cheers
quigleyth
