Diesel tanks
madpainter
Hi Wanting to know how can supply and fit 2 x200l diesel tanks for my 07 FG series canter south east QLD area.. Thanks len
Queensland Fuel Tanks have a good quality tank in Aluminium or Steel. Give some thought on how you are going to connect them together also if you are going to run other draws from them. eg diesel heater. Best to ensure the tanks are equiped for this. Also are you going to run sender units in each? Will you transfer fuel between them or switch from one take to another. My truck uses 100l from the aux tank before using the main tank. I then like to transfer the last 100l from the aux tank manually to the main tank via pump. This just ensure I never run close to being out of fuel.
Hope this helps your install ideas.
Steve
5mouse
