You're not giving us a lot to go on here. If it's a 5 lug LC axle from a 70 series truck, then a 6 lug hub from a 60 series truck should bolt on. That's just an example.
I believe it is a 70 series truck. I dont have much to go on either as differential is sitting on a pallet outside a tire shop. Guy that owned said it was from a toyota truck. I did see 2 yota trucks w/built on campers from europe that had same lug bolt pattern.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
