Dirty fuel filter (pictures)
WontonSoup
I replaced my fuel filter today with an oem filter, and I thought it would be fairly interesting to cut the old one open to see how bad it really was.
This is from my 2000 gen 2.5 with 150k miles. I have a feeling this is the original filter!
Here are the pictures
miloe79
What level of difficulty would you say replacing the filter is, from 1 -10?
Sent from my SAMSUNG-SM-G870A using Tapatalk
WontonSoup
Depends on how easily you can remove the banjo fitting. Mine would NOT budge with my breaker bar (even after letting it soak in penetrating oil) I ended up borrowing an impact wrench from a buddy and it zipped right off.
Besides the banjo fitting, everything else was straight forward. I would say a 2/10. Don't forget to replace the copper washers!
miloe79
Copper washers! Got it, thanks!!👍
SONICMASD
View attachment 388476View attachment 388477View attachment 388475
Hilarious, I literally did the exact same thing a 5 months ago! Got my new monty, fuel filter looked original, was impossible to take off cuz the bolt wouldn't budge, so i took it to a shop and had them do it and i told them to save it for me. I cut it open with a hack saw and it looked just like this. Actually, I think yours is a bit worse.
JamesW
This is what came out of mine after I found it having trouble starting and being a bit weak up hills
Sent from my ONE A2003 using Tapatalk
Sophia Lopez
