Wrathchild
Just wrapped up my dual battery and solar setup. The starting battery is connected to a northstar group 31 AGM via the blue sea ACR and disconnect.
On my Victron monitor I am seeing about 100 - 200 mA discharge from the AGM into the truck battery (solar and all loads disconnected from the house battery). I know for a fact it’s discharging into the starter battery because I can make the draw go to zero by switching the disconnect to off.
The ACR is functioning correctly. But it would take a really long time for it to isolate since at rest my starting battery is above the 12.75 volt threshold.
The starting battery is in good shape, only about 4 months old. I replaced it in anticipation of the dual battery and wanting both batts having similar strength.
Should I be concerned about this small discharge?
I assume this is just one of the pitfalls of having slightly dissimilar batteries wired in parallel.
It’s not a big deal to me if I need to connect them when I want a good bulk charge from the alternator. But I would prefer to have them connected and just do their thing without my input.
