discussion on Torsion bar for flippac on an engineering site
trump
Adventurist
LOL! The mind of an engineer is a busy, busy place.
What do you mean by adjusting the lid alignment?
Martyn
Alignment:
The hinges are bolted to the main shell and the lid.
Access to the bolts is via holes in the inner shell.
Lift the lid to a vertical position
Loosen the bolts on the side that needs to be moved
Re-tighten bolts
austintaco
Thanks again, Martyn!
My lid has shifted so that it closes with more overhang on the driver side. To get it to line up, I have to tug on the lid while my wife does the passenger side clamp.
I'll take Martyn's advice and get that lid straightened out. Pun intended.
4xdog
I don't quite get some of his assumptions. Maybe there's more than I realize, but 500 lb as the weight pivoting on the hinge seems high. And 95% of the deployed weight acting on the torsion bar also seems very high -- I thought that was mostly a static load borne by the hinges and the hood prop rods, not the torsion bar.
To aid flipping open of top a torsion bar seems a simple and reasonably well-engineered solution. The op seems to be expecting more of that torsion bar than I apparently am...
Don
r_w
6 places of precision based on a bad assumption. We used to call them paper engineers, now I guess they are keyboard jockeys.
No common sense, never actually picked up a tool or tried to do what they are building. All engineers need to work as journeymen, mechanics, maintence, etc. for what they are designing before/during their schooling.
I learned WAY more working on the farm or in the engineering shop than I did in class on how to be a real engineer.
Sorry, rant off.
But I, too, have marveled that the torsion bar failures are as low as they are. It is a pretty insane job they are trying to pull off--if this was .gov work and you could spend $1000+ each, sure, but to do it on a budget?!?
Clemtiger84
