Patterning
Alright...got some work done this morning. I got the base patterned out.
So what you are going to need is outer material, double sided tape, marker, scissors, your choice of insulation and patterning material. In this case I am using duraskim.
Next apply your double sided tape to all the edges that you will need to sew together and where you will have an outer edge. You are basically tracing the outline of the object you are patterning.
Its hard to see but once you have everything outlined you need to take your marker and place indexing dots on all corners and some periodically down the run of the tape. This will allow you to line up your fabric later on.
Next take your patterning material and place it on your double sided tape. The goal is to create a smooth surface without wrinkles. So you might have to reposition that material a few times. For instance in this pic you will see that on first try I had it lined up very well..
But in this pic you see that the bottom was off. You can't have "off"....
So you can see in this pic I re-positioned and now I have some overhang, and that is ok...
On the bottom edge you can see that it is rounded. So you will have to create something called a "dart"...It is basically just pinching out the excess material...
Continued.....
