sjstar
Hey guys,
The main reason for my post is to share with you my rear drawer/kitchen setup that I built for my JKU. I want to inspire others that day dream about the great overlanding organization systems sold but either don't have the funds or have a wife that would ******** a brick if you even brought up the price. Don't get me wrong those systems are so nice but my eyes are bigger than my wallet. Hopefully I can share with you my build and get you thinking about going out to the garage and building yourself one. The main reason for myself to build a organization system is just that.... to stay organized. When most everyone goes camping you tend to bring a lot of stuff and like many vehicles the only option is to just stack stuff on top of stuff. That sure makes getting to those items at the bottom a real pain. Especially when the bottom item is always a cooler. Another great key to the system I made is its all modular. So first I cut a piece of .5" high grade plywood as the entire floor and layered it in carpet. This creates a base for your system to sit on and bolt down to. So my two sides are separate from each other, this allows me to leave just the fridge side in most of the time and when my drawer side out in storage it is also where I store all my camping gear that I would normally have in it.
The best way of tackling a project is to spend the time and think of :
What do I need to take camping?
What do I want to put in drawers?
What layout is going to work best for my setup?
What do I need to fit in the drawers, as that might dictate how tall each drawer is?
Then once you have your idea in mind take a notepad and try and sketch out the measurements. This will make it soo much easier when it comes time to cut your material because you can cut it all at once and then assemble it.
The stores I used for the project were:
Home Depot for the 1/2" plywood, screws, glue, and carpet (made 100% out of used plastic bottles)
Mcmaster.com for the drawer slides, and track tie down system
Amazon for the latches
The ride side uses a 50qt. ARB fridge mounted on a 26" locking open/closed drawer slide with a 24" drawer underneath that houses the legendary/inexpensive Coleman stove. The wooden drawer that houses the Stove is lined in a thin sheet of aluminum to aid in clean up and prevent the wood from being exposed to fire. The fridge/drawer system is housed in an open back and front dog house to allow you to place items on top of it while allowing the cooler to slide out.
The left side is made of three drawers: the lower is a 30" drawer, middle is 17" and the top is 24". The lower drawer houses the pots and other kitchen equipment, the middle houses most of the dry foods, and the top is misc. camp equipment. The middle drawer is only 17" deep because behind the seat is a 6 gallon water jug that is "frenched" into that back of the cabinet. It had to be up above the lowest drawer because that elevation allowed me to get enough gravity water pressure in the hose not to have to run a pump. The drop down table I also made myself is a piece of carbon fiber that I got from an old Lockheed Martin assembly building (I have sheets of it). That works really well and looks cool too. On my ARB Fridge I also sewn on a piece of stretch material so I could keep my big pan and cutting board housed there. Pelican trekpak is a great product to by for drawer dividers but I came up with a DIY version. I used a product call Skudo (coroplast sheets will also work, you can get this from many construction supply stores) and some garden drip system Ustakes to keep the sections together. The Skudo or Coroplast comes in sheets and I used a table saw to cut the desired pieces. The homemade dividers is very very similar to the trekpak and works really really wellMaking the dividers is really easy and very easy to adjust too.
