Dodge 2nd Gen Wheel Question
redthies
Renaissance Redneck
Is anybody running 35" tires on the factory alloy wheels on 2nd gen Dodge 2500s? I would guess there will be some rubbing depending on tread width. Thoughts? Pics? Thanks, James
D
DEEZLPWR
Guest
ive got 34x12.50x16 on factory rims, i have 1/4" spacer and i barely rub the lower control arm.
the bad thing with the unit bearings is that when you run a thicker spacer it will wear the hubs down faster.
this is all with a 2" level kit up front though, made a big difference. I am going to run 35"s next and get them 35x10.5"x16 this should keep rubbing to a minimum.
2001 2500 cummins long bed ex cab.
chasespeed
315/75-16s on 2nd gen factory forged rims....
Click the thumbs for bigger pics...
I rub at lock. I pondered getting hub spacers. I think the best thing would be some aftermarket tubular arms... longer while we're at it......
Just my thoughts....
Chase
cowboy roscoe
35x12.5 BFG ATs slight rub on control arms at full lock
I have a gen 2 (98) with stock wheels. Slight rub with BFG ATs at full lock.
kabobkabobkabob
