Dometic Brisk II 13,500 BTU A/C Black RV Van Roof Top Air Conditioner
vtsoundman
OverAnalyzer
Black Dometic Brisk II A/C unit removed from Sprinter van - barely every used. Capacitor soft start installed to make starting on small generators and inverters easier. Unit is approx 2yrs old, van had <8,000 miles when removed and hardly ever used. This unit is a ducted unit - so it will require a 'pretty panel' if you want to install it w/o ducts in your RV or van. Has a small crack in the outside housing and some small scuffs. Was working when removed.
This unit is extremely efficient and very powerful. Comes with Remote thermostat and fan speed switch.
DOMETIC BRISK II AIR
13,500 BTU ROOFTOP AIR CONDITIONER, DUCTED APPLICATION.
The Brisk II's smart design and improved materials combine to maximize air flow and performance. It is best-in-class of any standard RV rooftop air conditioner for weight, air flow and capacity. Tested for use in extreme conditions.
13,500 BTU
COOLING CAPACITY
LIGHTWEIGHT
EASY INSTALLATION
SF Bay Area
$350
Van not included.
FiscAnd
