Dometic CFX 50W - Help
fjtonka13
Hello all, I'm now to this forum & was wondering if any other Dometic Frige owners have experienced this same problem.
I have a CFX50W that I've used only about 4 times, I'm checking over my gear for an upcoming adventure so I grabbed my fridge from my house garage to get things staged for my trip.
Decided to test out the fridge & it has an eRR2 or something like that on the display & would not power up... waited for a couple of hours & this time it powered up via AC plug in the house to test, then the temp. display showed 95F degrees but I had set the temp to be 40F in side the fridge.. noticed it just freezes everything inside while the temp display show 95F to 99F degree... I'm in Southern California and temps her have been in low 80's F outside... don't know what is doing on here.
Anyone else have this problem with their dometic boxes? If so, what if anything has been the process to correct this issue.
Thank you in advance,
Eddie
IvaBru
