SLO_F-250
Hey Guys,
So my fridge was working great till this past weekend when all of a sudden it stopped working correctly. I was cruising in the low 40's to high 30's when I got back from a hike and BAM 60 degrees in my fridge! No good. When I got home I threw it on 120V to see if that worked. I was down to 38 degrees in no time.
So, I tore it out of the camper today to try and diagnose the problem. I took it apart and cleaned orifice and burner. Mainly looking at this link http://www.rvmobile.com/Tech/Trouble/gassys.htm
There is nothing clogging the lines, nothing in the chimney, the baffle is there, and all looks well. Not to mention it burns bright blue and it heats up. Im pretty stumped now.
I dont think this model has a thermostat. Just High, Med, and Low for Gas. Then just for fun, I plugged it into 120 again about 3 hours ago and just went out to check it. 38 Degrees....
Any help would be GREATLY appreciated. Im headed out to Utah next month on the first extended trip with the rig and I need the fridge working.
THANKS
Back of the fridge & Baffle coming out.
Chimney Exposed
Orifice & Burner
Burning Bright Blue
Help Please! I would really appreciate it.
Thanks!
THANKS
![P4230350.jpg](http://i816.photobucket.com/albums/zz87/rpbelmont34/P4230350.jpg)
![P4230349.jpg](http://i816.photobucket.com/albums/zz87/rpbelmont34/P4230349.jpg)
Chimney Exposed
![P4230357.jpg](http://i816.photobucket.com/albums/zz87/rpbelmont34/P4230357.jpg)
![P4230353.jpg](http://i816.photobucket.com/albums/zz87/rpbelmont34/P4230353.jpg)
Orifice & Burner
![P4230351.jpg](http://i816.photobucket.com/albums/zz87/rpbelmont34/P4230351.jpg)
Burning Bright Blue
![P4230369.jpg](http://i816.photobucket.com/albums/zz87/rpbelmont34/P4230369.jpg)
Thanks!
