drawer comparison/input
Guinness44
Truckvault plus/minus?
Outback plus/minus?
any others?
the system needs to be stout enough to carry at least 400 lbs. on TOP. Inside, it will have tools, parts, fluids, also a LOT of heavy stuff.
Thanks.
spressomon
3+ hard used years on my AO drawers. Tough. Quiet. Well engineered.
A couple nits that are relatively easily solved if you're handy: The fridge slide doesn't have a lock to keep it in the open position (like when your cab is pointed up or down hill and you want the fridge slide to lock closed or open).
The second one, and again easily fixed if you're handy, on the stock configuration the drawer unlatches the fridge slide. What if you want to open the drawer but don't want the fridge slide moving too? Or visa versa?
Other than those two little nits I'd buy 'em again.
flipstick
