+ d
Make: Jeep
Model: Grand Cherokee Laredo
Year: 2004
Engine: 4.0L
Trans: Auto
T-Case: SelectTrac NV242, 2wd, 4Hi full, 4Hi part, 4lo
Front Axle: Dana 30
Rear Axle: Dana 35 w/Auburn ECTED Locker
Tires: 255/70-16 BFG AT
Wheels: Stock 16x7 Sliverblade
Additional Modifications:
Front Suspension: Rusty's 2.5" lift Springs +.75" Spacer,
10" Bilstein 5150's, Limiting straps
Rear Suspension: Rusty's 2.5" lift Springs
Protection: KOR rock sliders, Jeep Front Skid Plate, Jeep Transfer Case Skid Plate
Recovery: Jeep Front Tow Hooks, Jeep Rear Tow Hitch w/ Warn Shackle
Stillen Rotors & Composite Pads
Old Man Emu Steering Stabilizer (Blacked Out!)
Aluminum Spare + Spare Tire Well Storage Mod
Cobra WX ST CB w/ Little Wil mag antenna, quick disconnect
Hella Black Magic Auxiliary Lights
K&N FIPK
Silblades
Comfort Mods: Steering Wheel Radio Controls, Front Seat Swap,
Lighted Sun Visors, Cabin Air Filter, "shaved" antenna, ION Ipod Interface
Accessory Department: Hilift+Offroad Kit+Lift Mate, MV-50, Oasis Deflators
Pending Installations:
Spring Retainers!
Rear 10" Bilstein 5150's + Limiting Straps
Custom Headlight Harness + Hella Bulbs
On the Drawing Board:
Auxiliary Power System
Sway Bar Disconnects
Pipe Dreams:
4" Lift & 235/85-16's
Exhaust/Headers
Mojave/BajaTaco style Hide-a-winch
Currie Rear End
Some Pictures:
Locker Thoughts....
after watching a totally stock tacoma trd (w/ locker) driven by an offroad novice walk through an twisty turny wash that made my jeep barf up its springs I've decided it was time for a locker. My old man/copilot likes the idea and has expressed interest in helping me out. I've been researching these for a while, it seems like the next logical step for me.
part of my program for modifications is that it doesn't substantially alter or complicate the way the jeep drives and looks. it is currently our (me + wife) only vehicle. so naturally my preference is for a selectable locker. these are what I understand my options to be:
ARB - Air actuated - $ 750 + $ 265 = $1015
pros: most popular option, forces onboard air, relatively easy to operate (2 buttons), easy to mount buttons, matching front locker available
cons: most expensive option (by far), air line actuation doesn't inspire confidence, most popular option (why follow the herd)
OX - Cable activated - $ 690 + $ 80 = $770
pros: reportedly bullet proof, comes with beefy (good looking) diff. cover, low tech, able to lock/unlock at diff if actuator fails, matching front locker available
cons: expensive option, mounting/placing/routing of cable and lever limited and maybe difficult (and more invasive), cable actuation may not be totally user friendly,
Auburn Ected - electric (supposedly available soon) - $ 550
pros: least expensive, push button operation, simple to mount switch and run wires..right?
cons: marketed as a traction control device...appears to wire into vehicle brain?, unsure of actual operation..not yet available
to complicate the matter part of me wants to take the opportunity to really gold plate the whole situation and upgrade my axles at the same time. dana 35's don't have a good reputation when it comes to big tires and torque (which isn't my situation now..but could be down the road). In which case I would be looking at one of the "Super 35" (or similar) kits from Superior, Yukon or Alloy Usa. These kits allow for a beefy 30 spline axle (dana 44 sized), I'd need a special Dana 35 30-spline locker, which appear to be available for all lockers listed above. This Yukon kit adds 'ONLY' an extra $200 (though installation cost will increase as well I'm sure). Of course all of this hinges on finding an axle for the WJ or adapting to my 5x5 bolt pattern (which is different than every other jeep...%$!*ing Chrysler)
So, I'd really like some input from you guys. I'm anticipating a large number of votes for the ARB but something really draws me to the OX. Thoughts???
