tsherrygeo
Hi All, with all the downtime at home I'm finally getting around to building out the back of my 99 Ford Explorer with drawers and a sleeping platform for camping. Now looking at electrical.
Background:
I'd like to run some LED lights and other accessories off of a second battery. Most of the info on dual batteries I can find is for adding a second full size battery to run MEGAWINCH7000 or fridges. I'm not doing that. Just LED lights, PC fan, phone charging, bike computer charging, camera battery charging, etc. The occasional laptop might be the biggest device.
I know I would probably be fine just running off my 750 CCA starter battery, but I like the peace of mind of having the accessory battery for trips where I'm parked a few days in a row.
I've read through much of Expedition Portal's famous cheap dual battery setup: https://expeditionportal.com/forum/threads/how-to-make-a-cheap-isolated-dual-battery-setup-for-50.77503/
As for location, second gen Explorers have a cramped engine, so I am thinking of locating it inside the back of the vehicle, either on the left or right side. I'm undecided as of now, if anyone has suggestions, I'm all ears.
Question: Is it safe to set up a small sealed lead acid battery like: https://www.amazon.com/dp/B00K8V2VD0/ as a dual battery with a solenoid as suggested in the $50 Expedition Portal thread? I am worried about overcharging a small battery.
Would I be better off getting one of those "smart battery isolators" https://www.amazon.com/dp/B00WTAFR5W
With the smart style isolator, do I still have to run a wire between negative terminals on both batteries?
The "Easy Button" option might be to just use a portable power source like this: https://www.amazon.com/dp/B07FYJVFNK. I want to price out my various options before whipping out my wallet.
Thanks for any advice.
-Tim
Background:
-Tim
