Ramdough
Looking at a large truck setup with a 54 gallon tank and a 100 gallon tank.
I plan to have a transfer pump from the secondary tank to the primary to use to refuel as needed. The primary tank will feed directly to the motor.
Would you use the 100 as primary or the 54 as primary. I am leaning towards using the small one as primary and then transfer multiple times as needed.
Thoughts?
Thoughts?
