maust
Background:
A few years back I picked up a M416 with plans to build an expedition trailer taking the RTT off the Tacoma and putting it on the trailer. While I can turn a wrench, I don't have access to a welder. Initial plan was to have a flip top lip, but then access to below would is limited. Building on top of the deck raises the center of gravity and increased fuel cost when pulling on the highway. The trailer is solid and pulls straight, but it is no show piece.
Seeking Advice?
Thought is to have a pull out kitchen and I have 48" long slides already. Thought is to use a mix of wood and 80/20 framing a box approximately 2 foot tall on top of the trailer lip. Access to the trailer bed would be great hauling gear and water tank. I also have some 1.5" rectangular tubing that I cut length wise and could perhaps use if I could figure out why it bent after cutting.
Currently, I'm rewiring the trailer, to include the blackout light, as the prior owner die some questionable work.
Concerns:
I'm worried that If I build a box on top of the trailer lip that a bump in the road (or off road) could sever the trailer and upper build. Am I over thinking this?
If it helps I'm located in ABQ NM
Seeking Advice?
Concerns:
