E350 4x4 conversion parts NorCal
‘05 E350 midship gas tank and shortening kit for 4x4 conversion.
I have an extra gas tank that came out of a 2005 E350 V10 complete with sender, straps, filler neck and the kit to shorten it in order to clear your transfer case. If you’re doing a 4 x 4 conversion on an Econoline, this allows you to get the tank bobbed ahead of time so that you’re not stuck waiting for a fabricator to weld it up.
this will fit a bunch of different years and engines.
Located in the far North Bay Area. 95451
Asking $400-
Open to trade for other E350 build parts.
Pick up or meet within a reasonable distance.
5R110 output shaft, mount, linkage and tail housing to fit an np271 transfer case.
Included is the Switch and wiring harness for 4x4 the indicator light.
Asking $300 for everything.
1reddog48
