non_applicable
I'm looking at purchasing a 2009 chassis cab, e350, 6.0. My first question, is if the dually rear axle (I believe it is a full floating Dana 10.5") is more narrow or more wide than the typical Dana 60 that's used with the UJOR system? I'm wondering if it will be a problem just running a single rear wheel on this axle, under a SRW service body.
The van does not come with a service body, I intend to purchase one and install it. My second question, is how does the service body (or any attached body) actually attach to the front cab? I'm planning on doing a walkthrough from the cab to the service body, and the chassis cab is completely open in the back like the one pictured. Is it reasonably simple to mate the service body to the chassis cab? It looks like it is, I just want to get some feedback.
My last question is if the 55 Gallon fuel tank, or the mounting location for the rear springs, or if the additional 4inch distance between the rear spring mounts compared to a SRW e350, will cause any problems or concerns with the 4x4 swap and lift itself?
Thanks for any help here! I'm ready to pull the trigger on this and get my conversion started, I just need to make sure it's not a mistake for some reason.
